Yeah attachments might work. As hot as they are, I'd rather not be caught with half-naked asian chicks on the screen and suspect URLs in my proxy logs :laugh: Ghey rules at work, I want hot asian chicks dammit
we all want hot asian chicks at work marc, its just a matter of firing the ones you have and replacing them with hot asian ones................O..............M................G!!!!!!! i know what i am doing tomorrow now!!!!! goodbye pubmoles, hello hot asian girls :(
also, could be worse marc, you could be caught with half-naked guys on your screen, which would you prefer?
Later bishes off to work for me it is!! Cheer up emoanna!
cya
yeah go cut your wrists for a bit, emo's like that dont they?
oh why sad anna?
you want more photos of chickens?
I like chickens...
i know what will really excite her, A SPIDER :laugh:
bish
ciao!
i know what will really excite her, A SPIDER :(
or a Penis!
well how was i suppose to know what the farkin mercury was, fool :laugh:
farking Looser......
hey anna did you ever go there during the Dome days or even the underdome? man chicks back then really knew how to have fun, now they all uptight and just hang with their friends, never want to meet new people.....
Bond Uni nights at the Drink FTW!! :mad:
it is FULL of cute asian chicks loser :D
:mad:
well how was i suppose to know what the farkin mercury was, fool :(
because you should
oh, i'm sorry anna :(
does this make you feel better shane-> :laugh: <-anna
lee, i am coming out with you one night then, show me these places of interest
a bit slow shane Linh comes back tommorrow so we just have tonight ( :( that sounded really gay :laugh: )
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
