good thing for me my parents are giving me 2k towards anything i want for my birthday this year, i'm going to japan autosalon next year :happy:yay for me. if any one wants to come too they can (i'm not paying though) want to get a big group of us over there
There is always a group of SAUers in Japan. And several of the NSW guys do TAS each year too. My goal was this year. But it's definately going to have to wait til next year.
why are asian girls so cute :P just dont get it :) they must get fed hello kitty from birth :P
Ahahah, have you seen the simpsons episode where they go to Japan and they see the Hello Kitty factory. It's a conveyer belt with heaps of kitties on it :(:):P
Ahahah, have you seen the simpsons episode where they go to Japan and they see the Hello Kitty factory. It's a conveyer belt with heaps of kitties on it :P:):P
hehe yeah that was cool
and lee........you suck :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
