ok well what night are we all going out to get pickled again???
hell yeah! i'm up for that!
just make sure your not a family function when you do it...
*shudders* oh thats so wrong, we arent in tasmania
thanks mike but I find it hard to meet let alone pick up these days
no, i meant if you want sex you better asked better than that! i got bookings this weekend so you better be something special >_<
ok, i think its time i went for lunch. be back soon bishes!!!!
*flys out the door*
thats a pretty weak sauce attempt at asking for sex troy :happy:
hehe no, i would literally kill you if you tried to touch her, i'm very protective of this one, she's like family to me. since i'm not from tasmania, it sorta rules out a few options :P
the last person that tried to do stuff to my Belle (thats her name) got thorwn into a brick wall face first
awwee come on mikey, ill be nice, i promise >_<
no, i meant if you want sex you better asked better than that! i got bookings this weekend so you better be something special :happy:
*flys out the door*
hahaa its locked, sucka >_<
*** the SAU Pub Crawl rocked big thumbs up to Anna and Andy for taking the time and moneyu to organise it ***
YAY! Andy was talking last night about making another pub crawl very soon >_< Rules will be the same, punishments will be handed out, and DC status remains.
Annaaaaaaaaaaaaaa i missed out on steak last night :spank:
:happy:
Hullo darling :P I miss you *sigh* this has got to be like, you're ONLY post in Qld :(
Where were you? Huh? Huh? Ooooh, guess what I had for dinner (hint: as per usual when I visit a steahouse, it was NOT steak >_<)
Oh and will you be in Sydney end of Feb (24th)?
Hullo darling :happy: I miss you *sigh* this has got to be like, you're ONLY post in Qld :P
lol
Well you remember that you told me about last night when i last saw you........ i forgot and Andy told me last night at 6pm my time lol
Im down this weekend for more tests then have the Saturday and Sunday free.
So i will just miss you :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
