I speak the truth...I cannot edit posts in whoretown :O
*innocent*
just like when you DIDNT edit lee's post that you admitted to doing last night, hmmmm?
yeah damn straight i spose it depends what the owner does with it, cos i've seen some hot 33's, but some of them make me wanna cry they are so effin ugleh!
why do people ruin such nice looking cars?
I would mind one of each :)
wouldnt everyone though
hey nothing wrong with an auto (my 200 is an auto). I understand about the rims it is so hard to find a nice set that really does the car justice, but press on cause when you find the right ones the car looks even sexier
yeah exactly.. I'll know the ones I want as soon as I see em, just gotta wait till then, cos I won't settle for ok rims....they gots to be da sex!
the sideskirts wont be on cause they dont fit.
PISSED OFF ABOUT THAT! :)
But front bar and new review mirrors are being done today and tomorrow
other then that, the car will be ready for what can be done to it now.
PSI Parts have shit me right off this time and i am not happy.
would you like a highflow that actually makes the power now ? :O
know what ya mean
this is my dream:
track built 32 gtr (getting there, shuddup everyone lol) 33 gts-t in black with gtr kit and gold rims (just like my old car *cries*) and 34 gtr
yesss that'd do nicely :)
maybe u can join me in looking for husbands
LOL
nothing
im completely innocent!
ha ha ha
way to make it sound seedy loser bahahahaha
On xmas day I was driving home and he happend to see me with my mum as my passenger...
YEAH THAT'S RIGHT!
I cruise with my mum cos it's da coolest!!!
bahahaha
I was giving her a lift! JEEBUS!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
