Chatting with a fellow sau money on msn. Nobody scared me off Lee.
I'll take on that bat with my breaker bar in the boot and crowbar under the seat. The crowbar is bright blue! I call 'em Bluey!
When I lived overseas I played little league... I know how to swing it baby!
did i miss something good :(
ha ha ha your driving round in a skyline with a crow bar under the seat especilally with that skyline bandit dudes and copy cats.....
Ben:"good eveniung officer..."
cop:"Can you explain this son...."
Ben: "errr... i use it when i go camping?"
Cop: "sure son...."
Ben get taken in for questioning....... ends up get ass raped by the justice system, has to sell skyline to Lee for 10K cos he has to pay fines........
:nuke:
he he he trying to make enough money to pay for the 33 and yours
hehehe
OUCH
lolz i'm using that time to take time off work, and sleep :nuke:
plus i gotta do the dodgey on the timesheet, caus they dont like it when people do stupid hours like that (wednesday was a 18.5hr day :()
damn 18.5 hours thats crazy
yeah, i realised i was in trouble at about 2:30, so i turned off my email system and logged outta SAU, went flat stick from then on and left at a bit after 2:30 in the morning
How many drawings did u end up with in the end?
I live near Browns Plains. I need protection!
Been thinking I'll ditch the crowbar... but it scares people better then the breaker bar. The bar is there as I changed my lugnuts and they are a different size (doh!) so got the bar and a socket to suit.
Find it better then the others you can buy as replacements as it's got a nice handle and longer (sidchrome ftw!).
Lee as if take my skyline... I love my baby! Now if only I'd get ahead enough to stop repairing things and get some mods!
they are a adjustable heel fins you waer the boots as well so when you are reef diving you don't cut your feet open and the staps don't rub either. the beauty with adjustable strap ones is that they are quick and easy to get on and off :(
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
