Some of the guys on here go every year. This was going to be mine and andy's year too. I wondered for a bit why I didn't have the money to go, but then I worked out that i'd spent approximately $5000 on Sydney trips this year :P
I mean last year
Oh while I remember if anyone is keen for another night at the Catwalk Club, I might know someone who works there and can help us out... :P
Stop tryin' to sound clever marc. I know the kind of students they churn out of ippers grammar :)
Uh oh, my cover's blown... *runs*
i think i might make this a destination to go to next year!!!!!
hrmm!
jan 08
this can be done.
just got to remember that i got to save for this in nov.
dude, long day...
court first up this morning
gettin phone calls all day about the colour matching issues we are havin with my car
not only that, im at work copin shit from everyone cause i have to put up with a bunch of computer n00bs every day around here.
on top of that, resolving this bullshit with *.
dude, long day...
:P damn, sux2bu
help us out you say?
u r aware a majority of us do have partners and dont need helping out???
lol
So? Bring her along. She'll love it. She's a regular carpet muncher, I can tell :O:)
hey marc how bout next weekend (27th-28th?) I know dave will be up for it :O
Ooooh, last weekend, I did mention the idea of going to a 'new' place, but Andy really wasn't keen on going anywhere that didn't involve Serina :P
lol
Err yes, I'm one of those people who has a partner... last time I went to the Catwalk Club she came along. And it was f*cking excellent lol
*remembers*
*private time*
you seem to be losing your touch john? that was pretty average :)
:P
Yeah we'll have to organise it, I don't know how much notice we'll need, and I'll also have to match up with her shifts.
dude, long day...
how dod court go??
do we stand a chance? just tell them all to restart their comps and get back to you :P
im sure you can make me happy tonight :)
nah, i'm busy tonight. got a friend down from sunny coast to see me :O
So? Bring her along. She'll love it. She's a regular carpet muncher, I can tell :D:O
Serina! is that how its spelt, or you dont know?
nah, i'm busy tonight. got a friend down from sunny coast to see me :)
That's how it's spelt. It was imprinted on our sheets after we got home time before last :P
Long story, basically she took to him with a black felt pen and wrote over his entire body.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
