"this is a song by teddy geiger called 'these walls'. It is one of my all time favourite songs about walls. Big call I know, but that's how I roll peeps"
hahaha roflcopter
Mr Marc...
how'd you recover after our 3.30am cruise to the coast?
lol
Good, slept until about 2pm :D
lol
i went out, did the other photoshoot, got home at 9.30ish, slept till 1 and got up again and did another shoot at 2ish
then got home, slept another 3hrs and then woke up, ate and slept all night
thank god these photoshoot wknds r over now.
ahh yeh
dude :)
i happen to like fishing and we caught heaps....
i was just disssapointed at not being informed......
is that a Nappy????? that dude looks some what like Shane!!! ;)
dude :)
is that a Nappy????? that dude looks some what like Shane!!! :laugh:
Now that you mention it... ;)
Nah the "cruise" was just Karen, John and myself doing the SAU Calendar photo shoot. John wanted dawn lighting, which meant leaving his place at around 3.30am.
Oh k this basement jaxx song is starting to give me the uber shits. I have a feeling that it will be played atleast twice more today before 5pm, and if that is the case the radio will not live past then either :);)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
