I was at work, and i was serving a customer with the sirname "condon" i walked out the front, and asked if customer condon was there, boy o boy did i get the weird looks, eventually i had to get onto the audio system and page customer condon to the counter.
pointless story sirname was funny, i always have served a customer GROGAN, KUNTZ and FAGG
*starts singing circus music* hehe
well, now i'm bored, your turn
*sings*
YOOOOOOOOO I'LL TELL YA WHAT I WANT
WHAT I REALLY REALLY WANT
SO TELL ME WHAT U WANT
WHAT U REALLY REALLY WANT
I WANNA HUH
I WANNA HUH
I WANNA HUH
I WANNA HUH
I REALLY REALLY REALLY WANNA ZIGGAZIG AHHHHHHHHHH!
I actually met a guy once whose name was Wayne Kerr lol
There is a guy on our compliance unit called Wayne King
Thing is he is the scariest mo fo I have ever met, he was the lead investigator in QLD during the Joh years....and he has been shot 4 times and stabbed 3 :)
And when ever we go out on site he tells me how many times he has been shot and to watch everyone carefully cause he is "He is sick of getting shot and too old for it these days" lol
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
