Hmmm... perhaps we need to ALL motivate each other!
I need a neighbour like ado to message me saying 'get off your ass fattie and go for a run'. Although I have been good these last 2 weeks. Eating better and exercising. All the usual shite you do to try and make yourself feel better :P
Chocolate Mud Cake from the Cheese cake shop makes you fell better :devil:
ha ha ha yes we all need an asshole neigbour who pays out on your physical appearance.. LOL
i swear he gets so much enjoyment out of being able to call me fatty without getting a beaker of acid thrown in his face
:laugh:
your a voilent one.......
but are you all talk?? :devil:
:devil:
lol bridget told me about your nanna, and your photoshopped catwalk model (i think on your fridge) :devil:
I could make my housemate do it...
Nah I would just ignore him :devil:
:P i only said i think we've discussed this before..... lets all post up photo's of our nipples :devil:
This is me being emo EMO NIPPLES - NWS
oh k!
still got the problem with drinking softdrinks though.
Switch to diet my good man! BIG help :laugh:
:devil:
my nan is friggin crazy... she's so cool, i can't wait to get old and senile... it's like being a comedian!!!
yeah i think i have one of my photo's here.. LOL it was before photoshop, so it's only a paint job :laugh:
this is me after I do weights....
it's pretty acurate... LMAO
the other ones are my face on annorexic models that I keep on my fridge to "inspire" me not to eat BAHAHAHAHA
"our" brass knuckles???
u wanna marry me or something?
:huh:
:P
well maybe I have a cyborg arm that will own your plate yo!!!
:devil:
An what if i do???
dam that cyborg arm.... wait let me call Arnie over!! "I'll be Back!"
:laugh:
so who wants to go get a car wash at mt gravatt
Your treat Lee??
but yeah i'll be up for that this arvo....
oh k!
Nice Nipples, but i'm abit wary of those D.I.Y. Breat implant home kits :devil:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
