Its a Twin, what more is there to say? :laugh:
I have it on good authority from several people who arent the ones trying to sell you something that your clutch is going to lead an interesting life. But Only time will provide ROFLs. My clutch is allowed to slip it has spent the best part of 13 years running at well over its rated HP :action-smiley-069:
Morning yall
hey bryn, how goes things?
13 years, that isnt too shabby :laugh:...if a single can do the job, then why go twin/tripple/quad
QUESTION
I am applying for a job within my department. Do I
1. wear the business shirt and tie you know usual office stuff
2. Wear the uniform of that department, long pants and the polo
I say the shirt and tie... You don't want to look like your relying on the fact that you work for the company already..... shirt and tie shows you're serious and made an effort :action-smiley-069:
GOOD LUCK!!!!!!!!
Thanks :action-smiley-069:
13 years, that isnt too shabby :cool:...if a single can do the job, then why go twin/tripple/quad
cause a twin cost me $200 :( And it can make amusing rattling sounds and n00bs go ZOMG your car is breaking
I say the shirt and tie... You don't want to look like your relying on the fact that you work for the company already..... shirt and tie shows you're serious and made an effort ;)
Point taken
shaving ftl
agreed :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
