get me some redline shockproof oil while your at it...i'll pay you back :yes:
pfft redline, motul ftw
those boys are fun to stir
LMAO
they get real angry :stupid:
ooo so u found ur way to the wasteland ey
after seeing your myspace pics i think they want you to rub one out for them.
HI5 :sorcerer:
come to dinner to night bitches...
u pay for my drinks n ill be there (also give me a lift from a station)
Holy shit I think i'm brewing bourbon in my stomach.
My mouth tastes like jimmy! :yes:
"brewing bourbon" you say hmmm.....
is that what the call it now days??? ;)
WHO'S JIMMY?? :stupid:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
