Hot diggity damn I can! You even get to go all stabby stab on it. Cos when you pour it into the pan, you let it set, then when you take it OUT of the pan, you have to STAB the shit out of it to break it up! My honeycomb is good... but I prefer the spearmint marshmallow covered in roasted coconut *drools*
What the hell we have a chef on our hands?!?!
That's awesome ..
I wanna make honeycombs :P
CRUNCHIES!!
CRUNCHIES!!!!
THE CHOCOLATES!!!
I LOVE THEMS!!!
ok, gotcha, brain not working today
DON'T TEMPT ME!! :P
do it! do it! come on, burn something. i heard hair burns well
i wouldn't go as far as saying we WORK for Telstra LOL
But we show up yes.....
well put
Noahs Ark
When the Ark's door was closed, Noah called a meeting with all the animals. "Listen up!" Noah said with a demanding voice. "There will be NO SEX on this trip! All of you males take off your penis and hand it in to my sons. I will sit over there and write you a receipt. After we see land, you can get your penis back."
After about a week Mr. Rabbit stormed into his wife's cage and was very excited. "Quick!" he said, "Get on my shoulders and look out the window to see if there is any land out there!" Mrs. Rabbit got onto his shoulders, looked out the window, and said, "Sorry, no land yet." "Darn it!", exclaimed Mr. Rabbit.
This went on every day until Mrs. Rabbit got fed up with him. Mrs. Rabbit asked, "What is the matter with you? You know it will rain for forty days and nights. Only after the water has drained will we be able to see land. But why are you acting so excited every day?"
"LOOK!", said Mr. Rabbit with a sly expression, as he held out a piece of paper... "I GOT THE HORSE'S RECEIPT!!"
*bops head Brady Bunch stylez
And I could be your favorite girl, forever, perfectly together, tell me boy, now wouldn't that be sweet?
Woo!! Hoo!!! Wooo!! Hoo!!
not sum doof doof pls....
i love nova....
Blow jobs
A man comes home from work to find his wife in the bedroom, packing her suitcase.
"What the hell are you doing?" he asks. "I'm leavin'' you for a better life," she replies. "Where do you think you're going?" he asks. "I'm going to Las Vegas," she answers. "I hear they pay $400 for a blow job there."
The man thinks for a minute, then gets his suitcase out, and starts packing his clothes. "What the hell are you doing?" his wife asks.
"I'm going to Las Vegas, too," he answers. "I want to see how you live on $800 a year!"
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
