your bossom is 100 kays away :(
I see
*sigh*
heads for train tails for bus :(
Tails! Bus it is then!
ok will be at fasta pasta tonight as don't have a headache today :( (and cause anna scares me when she gets angry :P )
6.30!!!
we dont care
your a tool for doin a burnout.
might as well name ya a bogan too dude.
its really no wonder we (skyliners) have a bad rep left, right & centre.
Pfft get over it, Dont you do mountain runs? that aint a good example either.
mountain runs are NOT illegal.
we do them in due care and legally.
you on the other hand have done an illegal activity on a public road/public area.
i again state...
TOOL!
