mike there are many people that will just wait for the SAU track day then you can see who has the balls and skillz...
forgot all about that day :ninja: wait, its tomorrow isnt it. next one then.
oh well.
I should ad that the 12.4 was Gtech
Andy peopel can talk as much as they like, go shooting off their mouths...
doesn't mean any thing...
Mike... i saw a pic of your engin bay you'll be lucky to keep that thing running....
i saw the mod list and 250 even after a tune is a bit much.....
like we tell shane, save it till you have the car that actually runs and you can drive.... that you can drive being the main point...
oh well.
Read Here Mike
i think the day is 17th may... for Sau day anyway..... there are heaps of other times for people...
Can they what! This thread is the world leader for unfounded claims!
I know that I am not that good, at wakie I am sure my car can go 5 seconds faster than what I did...Thats why I need to get back there and practice :ninja:
bored!!!!!!
Bum sex?? :ninja: wait....
your a chick...... doggy???
hehehe
the lunch ladies gave me a Quicke... :laugh:
I know that I am not that good, at wakie I am sure my car can go 5 seconds faster than what I did...Thats why I need to get back there and practice :)
:kiss: new coil overs and i'll be able to have sum fun as well...
maybe you should orgnaise a sydney road trip :) i'll be in for that...
whats the layout...is it the same as what you get when you do a defensive driving course their?? Theory in the morning then...lvma for braking and wet steering etc? Then like a bit of skidpan in the arvo?? Or is it Theory then all skidpan??
Ummm, that is something I'll have to check on. Basically, it's not an 'event' yet. I am trying to get as much detail as possible to put forward to the execs. If they think it's worth it, then we'll run with it :)
At the moment we arent talking about this car you are buying..we are talking about a stock MX5
I will recap so every one understands
You said here is my evidence becuase a stock MX5 beat a slow R33,How does that relate to you in any way?
And I was saying that the comparison to the R33 is bunk because my car is nothing like that car and both in the above comparison were slow
My car weighs 1290kg (Yes I weighed it myself)
My car makes 260wrkw
My car has run a 12.4
Come winter I will more than likley be at the track, see you there
Do you have figures to back up your clai... oh wait. YOU DO! Bahahahahaah
Hi bunts. :ninja:
Ummm, that is something I'll have to check on. Basically, it's not an 'event' yet. I am trying to get as much detail as possible to put forward to the execs. If they think it's worth it, then we'll run with it :laugh:
Hi bunts. :ninja:
Hello :)
Anna email me when several posts happen, I cant afford to keep refreshing lol
Hello :ninja:
You mean your work can't afford to keep refreshing?
And yes, i'll let you know when lilmike posts something dumb again.
bahaha this is great...hi mike :ninja:
how was lunch with the old bags anna?
Just because he's taking the focus off you for a bit :)
Lunch was...
meh
Took ages and I now feel sick :S
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
