ok... here's my problem...
I wanna post up a pic I just received via e-mails.. but it's pretty gross....
Like I have an iron stomach and I think I was gonna bile everywhere....
What should I do?
As long as it's not the one about the chick who went overseas and the bugs ate holes in her boobs. Because i've seen that twice and I vomited BOTH times. Like actual REAL vomit.
ha ha ha ha nah it's not that, but I got that email aswell and I swear i felt bugs in my boobs... BAHAHAHA
:ninja:
But I didn't have bugs in my boobs...
:ninja:
Just though i'd clarify.....
or that Zit thing from You tube from the waste land forum....
or the chick who gets a picture of bamboo carved outter her back :ninja:
I personally think it's grosser than that... But I find things like the carving stuff cool...
it's cos i'm weird...
WHATEVER!!!
ok i'll post it up in a sec....
*vomits*
give me a few mins, im sure i can dig it up :laugh:
awww i not that mean :ninja:
:sick:
:ninja:
did u go crazy and start to scratch and stuff?
Interesting... *strokes beard* go on...
Get out *points to door*. You do NOT insult a homer quote in the midst of lovers of all things rediculously humerous!
call his wife and tell her your f**king him as well and ask what he likes done to him. order things and have them delivered to him, oooohhhh pizza's!!!! 50 pizzas
2 mins? i heard it was closer to 40seconds :laugh:
:sick::ninja:
A) as much as I wish I was half asian, alas I am not
B) I'm incapable of the feeling "love" it is foreign to me and makes me :yes:
:wave:
stop putting things in your ears then and you should be fine :ninja: it doesnt go there anna :(
This is the text I got with it....
I have a HUGE favour to ask:
My friend Louise is coming up from Adelaide on the 3rd Feb. She has
recently broken up with her boyfriend and is feeling pretty low. I'm
going to be organizing lots of nights out for her throughout Feb but if
anyone has any single friends that she can hook up with, please, please
let me know.
I've attached some pictures of her from happier times
:ninja:
:laugh:
:ninja:
OMG me too. That was by far the grossest thing i've ever seen. Just something about having holes (even though they were totally photoshopped) in my boobs makes me the seed. I'm feeling ill now :ninja:
or the chick who gets a picture of bamboo carved outter her back :sick:
See those were okay...
let me know.
dont hink we needed to see those photo's a second time....
WTF??? talk about Man Boobs :ninja:
let me know.
:ninja:
LAWL!
See this is why I feel sick...
It's actually a chick... well mostly a chick...
a hermaphrodite (however you spell it) if you wanna get technical...
:sick:
eewww.......
mikes gone quite....
:ninja::ninja:
Ahh I cant see the pics at work but if it has the carbon bonnet and the zelda force tri spoke wheels it is probably his
its dont have a cf hood, but the rims look like his, and i cant get over how good the paint is :ninja:
stoopid squizz for selling it and buying the dupra :ninja:
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
