ok... here's my problem...
I wanna post up a pic I just received via e-mails.. but it's pretty gross....
Like I have an iron stomach and I think I was gonna bile everywhere....
What should I do?
As long as it's not the one about the chick who went overseas and the bugs ate holes in her boobs. Because i've seen that twice and I vomited BOTH times. Like actual REAL vomit.
ha ha ha ha nah it's not that, but I got that email aswell and I swear i felt bugs in my boobs... BAHAHAHA
:ninja:
But I didn't have bugs in my boobs...
:ninja:
Just though i'd clarify.....
or that Zit thing from You tube from the waste land forum....
or the chick who gets a picture of bamboo carved outter her back :ninja:
I personally think it's grosser than that... But I find things like the carving stuff cool...
it's cos i'm weird...
WHATEVER!!!
ok i'll post it up in a sec....
*vomits*
give me a few mins, im sure i can dig it up :laugh:
awww i not that mean :ninja:
:sick:
:ninja:
did u go crazy and start to scratch and stuff?
Interesting... *strokes beard* go on...
Get out *points to door*. You do NOT insult a homer quote in the midst of lovers of all things rediculously humerous!
call his wife and tell her your f**king him as well and ask what he likes done to him. order things and have them delivered to him, oooohhhh pizza's!!!! 50 pizzas
2 mins? i heard it was closer to 40seconds :laugh:
:sick::ninja:
A) as much as I wish I was half asian, alas I am not
B) I'm incapable of the feeling "love" it is foreign to me and makes me :yes:
:wave:
stop putting things in your ears then and you should be fine :ninja: it doesnt go there anna :(
This is the text I got with it....
I have a HUGE favour to ask:
My friend Louise is coming up from Adelaide on the 3rd Feb. She has
recently broken up with her boyfriend and is feeling pretty low. I'm
going to be organizing lots of nights out for her throughout Feb but if
anyone has any single friends that she can hook up with, please, please
let me know.
I've attached some pictures of her from happier times
:ninja:
:laugh:
:ninja:
OMG me too. That was by far the grossest thing i've ever seen. Just something about having holes (even though they were totally photoshopped) in my boobs makes me the seed. I'm feeling ill now :ninja:
or the chick who gets a picture of bamboo carved outter her back :sick:
See those were okay...
let me know.
dont hink we needed to see those photo's a second time....
WTF??? talk about Man Boobs :ninja:
let me know.
:ninja:
LAWL!
See this is why I feel sick...
It's actually a chick... well mostly a chick...
a hermaphrodite (however you spell it) if you wanna get technical...
:sick:
eewww.......
mikes gone quite....
:ninja::ninja:
Ahh I cant see the pics at work but if it has the carbon bonnet and the zelda force tri spoke wheels it is probably his
its dont have a cf hood, but the rims look like his, and i cant get over how good the paint is :ninja:
stoopid squizz for selling it and buying the dupra :ninja:
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
