yeah i dont know much about them but i know i need one lol
but i will learn quickly. just gotta buy hand controller now. then il wait till i get further mods to my car before i install them all at once and get it tuned.
power fc are good, i went from 172 to 231 kw at the wheels with a pfc and slide highflow :woot:
oh and daz there's probably gunna be another skyline up your way soon :(:woot:
i be good little mikey, hows the car purchase goin?
i'm flying down there tomorrow to do an inspection. if all goes good i will transfer funds over on monday and it will be sent up here on the back of a truck (free mind you :( )
oh and daz there's probably gunna be another skyline up your way soon :P:woot:
you moving isaac :ninja:
i'm flying down there tomorrow to do an inspection. if all goes good i will transfer funds over on monday and it will be sent up here on the back of a truck (free mind you :woot: )
you moving isaac :(
wow cool, but wont you need queensland transport mod plates and stuff to register it in qld? are they able to approve that?
and maybe, i'm going for a job up that way yes :ninja:
and maybe, i'm going for a job up that way yes :woot:
already had a talk to rotary motorsport and they said for $150 they will mod plate it for qld. i'll keep the SA plates on it till i sort it all out though hopefully :(
ahh k
so are you at work today?
for one more hour, then i'm done till monday :( yay!! :balloonsandshit:
although i gotta get up at 4:30 tomorrow morning to go to the airport :woot:
The SAU forum shares the same server as the ATO super computer and with my Admin status it gets confused...
hmm well can you pls ignore my last tax return as certain things were claimed as maintenance that weren't really maintenance (fuel pump, clutch, brakes, dyno runs) :woot::(:ninja:
I'd prefer the slingshot if they actually launched them over the mountain...
i was hoping they would, or she'd fall out and go through the building. that would be funny :woot:
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
