looks like i'll be driving then :laugh:
its cool Shane i dont need a new engin yet.... do you need me to show you how to put a radiator cap on??
s14 motor (WAS).. clearance is the same as any sr20 silv.. so about 3inchs i think.... well i could fit my hand there... but after the accident.. there was no clearance.. the tunnel was squashed down to the gearbox lol.
do me proud son!
he He he.... i will
with the rb20 in the sil ther is like only an inch of clearence with the gear box droped...
but i did get sum interesting advice and am considering changing my engin to a RB26 :P now to find one and some cash...
dude, half the race is actually finishing lol
you'll probably break down half way lol
(sorry)
oh and as for the other pump... i don't know! It could have had a decent connection
lolz ur such a team player liz :laugh:
weird *shrugs*
he He he.... i will
but i did get sum interesting advice and am considering changing my engin to a RB26 :laugh: now to find one and some cash...
go a 2j, better engine
and all the trouble??? i told you rb26 is the better option, almost a straigh swap well according to Lucas...
as sif bring up which is a better option... thats only your oppinon and like an areshole everyone has one...
weird *shrugs*
hey we go kart drivers have to stick together
well.. my car has been complied and will be registered tomorrow! Then we begin the engine conversion!!! WOOT
omg i cant believe im going to do this but....agreed
find urself a 2j and a getrag lee and u'll be set!
you should have put one in the gtr. you would have had less problems :laugh:
lee, 2j IS a better engine. there is no opinion about it, its common knowledge. 2j is better built in almost every way. the rb26 is good, but unreliable. look at all the gtr's on this forum and count the number on the road. there is actually a workshop in brisbane that will do the swap for you no probs, they have mounts and everything already made up.
that's what i found when i did my first build up.. every man and his dog had an opinion, and almost every one of them talked absolute shit lol
just go with your gut, you'll thank yourself later!
i wouldnt suggest a 2j conversion for lee, its a bit costly, and really only useful in a straight line. it would overweigh the front of the car, ruining the weight balance.
stick with the rb20 lee and put a little bit of money into it. you dont need a lot of power to go up a mountain fast.
look at lowering the weight and balancing the car, you'll have just as much fun then. thats my opinion anyway
Edited by lilmike86
dont worry mike i looked into doing a 2j in the gtr, but if i was to keep the awd (which i wanted to) there woulad been too much custom work on the sump. give u an idea, the 2j has a stepped sump, the front section being 130mm wider than the bottom of the gtr block.
yeah i know, i saw someone trying to do one a while back, ending up scrapping the project because of the amount of money it would cost. in a silvia though, it would be much easier :laugh:
lol.. you just did!!!!
have u seen the weight figures between the motors? it'd be interesting to see, caus i doubt theres much between them
There a a few people who build engines for a living that can describe many reasons why the Rb26 makes a better engine in a full tilt application. There is a thread on it here in which SK describes why and I had heard the exact sentiments before
As a mild tune engine the 2j is awesome...as a "race" engine the 26 is better according to these engine builders
got linky to said thread? :laugh:
i wasnt serious, sif lee could afford a 2j conversion :laugh:
no there isnt, but every little bit counts on corners. when my new car arrives i will show you what even the slightest of balance adjustments can do.
that all comes down to opinion really. whether you can afford a full blown race engine or not. if we are talking one that gets rebuilt every few races then maybe, i'd go the rb26. but for reliability i'd pick the 2j.
i think we should stop this argument, remember what happenend on boost cruising when we did this on purpose?
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
