You......are
You..are
You are
Your.....
I mean You're...
thanks Squizz for the English Lessons :wub; (no i really mean it... i faild English in high school)
I think of it this way :
YOUR - ownership of something.. like YOUR FLACID PENIS
YOU'RE - YOU ARE like YOU'RE A STOOGE...
p.s. I wasn't talking about anyone here's woodle!!! before I get bashed or stabbed
:laugh:
Edited by LIL34
Again?
LOL when was I banned a first time?
:laugh:
i think shane got it the wrong way around....
yeah, tis me the bogan :( i cant help it, I cant be a bogan though, i dont own flano, and i havent owned pluggas in about 10 years :laugh:
Who called you a bogan.. Bryn your a Big Girl...
yeahhhhhhhh it's pretty sik.....
once i get my paper mache bodykit going... it'll be ready for show n shine... :dry:
Dude you forgot the Spinner Hub Caps....
look at them Spinning!!!
You tool. This is funny for two reasons.
1) Smooth has been here almost as long as I have.
2) Smooth is also named Matt and drives an IS200.
ROFL... gold...
I remember when uncle Jay had a 180... and a 32.... gtst..... na
HAR!!
PS: my Lexus is wayyyyy better than the other matt's
THEY SPINNIN THEY SPINNIN!!!!
has anyone seen Chris Rock's stand up?
CHECK OUT THAT TOASTER!! IT'S ROLLIN ON 22'S!!!
ROFL... gold...
HAR!!
This man speaks the truth, even more than me...
ITS 3 in the morning why do you need cash????
Ha?! Ha?!
Go buy thoose Spinners!!
(i think i got the jist of the quote) man its been a while since i saw that DVD....
i love the special feature part...
black man: why dont you date black guys?
Black Chick: oh.... No resaon
Black man: no reason hey?... Bam!!! *punches her in the face* Now you have a Reason BITCH!!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
