i'll swap my car and 5k cash for yours
ha ha ha i wont let my car go for less than 15 cos its so well looked after and never get thrashed... ask shane he can confirm this....
man its done 140 on the clock the engins done 90Km but have already done the 100K service in december... it has 200kws....
man i do really want to get a skyline but i love my sil so much.....
yes this man drives like a bitch :)
urs a S13 sil.. and 5k.. hmm haha i guess ill have to see it sometime at a meet.
the sil has tein coilovers, camber tops, castor tops, reco shimmed diff,
was originally a SR20DE 5spd, 92model. has a 93 180 running gear.
this what he sent me..
Red top Sr20Det 5 speed
heavy duty clutch
custom front mount
Arc bov
400hp walbro fuel pump
Remapped ECU
3" turbo back exhaust, Bee R Muffler
t28 turbo on running 1 bar
Trust manual boost controller
T28 turbo
16" Volk Racing CV Pro mags
Tein HA fully adjustable coil over suspension, pillow ball tops (height and camber adjustable)
Japanese body kit
momo steering wheel
Pioneer mp3 placer
Estimate power 170 rwkw. This car pulls away from most GTR’s running similar boost, but that’s only in a straight line. I have ran a 12.9 pass on it as well.
sounds ok to me.. but yet to see it in person..
thanks shane.. but the R34 will stay as sean drives it. and the GTR will go if anything will go.. ive had it for nearly 14-15months.. time to move on.. DORIFTO... :)
so
1 for keep the GTR
0 for trade for S13 oh and it makes 170kw haha :)
keep them coming..
170kw thats pretty poor......
keep the gtr...and make it 2wd.
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
sounds good
but compression &/or leakdown test are the first things i'd be doin
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
I would be expecting 200rwkw.....and then it might pull away from gtr's
Edited by Oblivion
heavy duty clutch
custom front mount
Arc bov
Remapped ECU
T28 turbo
Japanese body kit
momo steering wheel
Pioneer mp3 placer
Estimate power 170 rwkw. This car pulls away from most GTR's running similar boost, but that's only in a straight line. I have ran a 12.9 pass on it as well.
the car loks thrashed, does it have an LSD? cos the na sils didnt get them...
if he is willing to give you 12k extra the i would prolly consider it but man that car really looks and sounds like its been thrashed.... so he values he's car only a 8 grand...
but 12.8 at onlt 170kws?? i wonder how fast mine is???
give it to me and ill find out :)
Take it. You don't need massive power for drift. But then again i'm biased :)
yeah reshimmed reco LSD.. should be fine.. uh yeah 12k on top. thats with him getting all minor stuff done. eg wheels, wipers.. prob could get it with 13k my way..
i doubt it will be as quick as a GTR.. not mine :) haha anyway i intend on givin it a beating :laugh: and its a S15 ADM turbo..
first mod... RAS KIT :)
thats doesnt seem possible unless it weighs 900kg.....170kw is not enough to get it doing low 13's
yeah t28 housing are what the sr's use....if it is a t28rs....then it should be pushing 200+
well get the cash up to 13...
then you'll be sweet... you still have the 34 any way.....
T28 only come on the GTiR, S14/15 the S13 and RPS13 180sx use T25 and type x T25g..
the jap spec 15 comes with the T28 BB turbo...
not sure if the Aus spec did though...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
