Calendar fiasco???
well obiviously you havent seen the latest episode in the ongoing drama.
Let me recap for those with reduced/limited recall capacity, first we had a calender, it was organised and AFAICT ready for sale, but noooooooooooooooooooooooooooooooooooooooooooooooooooooooooo something happened and we were denied the opportunity to proudly display our club on our walls. not only that but we were left in the dark hoping against hope that it was going ahead, but nooooo again we werent even given the dignity of that information.
that brings me to the present day, after a lot of hard work by one person to try, it seems that it was all in vain, as I was eargerly anticipating the release of it yet again the thing has been once again stymied by......by well I dont really know this time which is no different from before.
Bryn says:
ouch
I am the real barbie girl says:
ouch like a minge with an STD
Bryn says:
hahaha
Bryn says:
u are random man
Bryn says:
really cute to
should i be scared?
Bryn says:
nah
Bryn says:
u shuld be turned on
my penis throbs
Bryn says:
hhehehe
Bryn says:
cut or uncut
Bryn says:
smooth or hairy
Bryn says:
top or bottom
*runneh*
Bryn says:
lol
Bryn says
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
