they r not really nice looking ones.. the ones i see in magazines are better ahahah.. grandma has better ones.. im kidding..
ive seen boobs.. unlike shane...
ur just jealous of my knockers! hmmph :)
zomg its anna! :)
zomg it's shane. hi hi hi hi hi!
I might get to see more boobs more often if tonights plan works! I'm so sick of not having work, i'm applying for bar/door work at showgirls. The bar and door girls suck and they are so unfriendly, and I know from one of the girls that works there that they are in need of new girls as all the dancers hate the current ones. I couldn't call to make an appointment, the phone number they have listed everywhere is wrong, and they have no email address. So i've gotta go in person!
ok uknw how u get bread.. and its sliced and ther is sometimes holes in the middle due to airbubbles and they expand and make bigger holes during the baking process. well u cant put tuna on the hole bit so my bread is not a friggen bagel...! GRRR :(
can we pole dance?!
sounds like a good plan to me, i'm sure andy will like that too :(
can we pole dance?!
Not at this place :( Hollywood Showgirls @ the Gold Coast has little areas where there's a mini stage, and big plush leather couches surrounding it, so you can sit and chat, or get up and play with the poles! If we go there, we'll have to invite Agnese. She's a horny latvian chick :mad::w00t:
yeh he's keen :laugh:
I've just got some ideas on how to improve the experience for their patrons. And their girls need an attitude makeover, too.
OMG I just got sent some pics of a party I went to a couple weeks back... f**k I can't seem to be in a picture when i'm not pulling a face! Be warned... these are NASTY shots!
post-22503-1172189306.jpg post-22503-1172189344.jpg post-22503-1172189357.jpg
Not at this place :w00t: Hollywood Showgirls @ the Gold Coast has little areas where there's a mini stage, and big plush leather couches surrounding it, so you can sit and chat, or get up and play with the poles! If we go there, we'll have to invite Agnese. She's a horny latvian chick :laugh::mad:
yeh he's keen :(
WHEN ARE WE GOING THERE?!?!?!?!?!?!?!?!?!
ummmmmmmmmm we're going to the ordinary one in Brissie tonight - I need to apply for this job ASAP.
Not sure about the GC yet. Perhaps I should organise to go out in a couple weeks time. She's one of my fave people in the whole world. So much fun and GORGEOUS into the bargain! AAAAND the one at the GC is FREE entry for ladies :(
definately !!!! Just let me know when and i'm soooooooooo thurrrrrrr :laugh:
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
