Learn how to spell or f**korf. Brats are so boring.
My spelling skills are fine, maybe you don't understand as I don't speak abo? Careful you don't throw a hip out replying in anger.
Nothings taken to heart shane...lol
Is it because I have money and drive a nice car i'm a daddies boy? Maybe I should buy a 89 GTR leave it unrunning in my garden out the front of my unattactive apartment, would that make me a successful independant?
I only ask as you because being a n00b and all, your opinion does mean quite a bit to me rofl.
ahh yes but you see, i bought my own cars (both the 33 and 32) and mod'd them with my own money. now, can you say the same?
btw, you obviously don't work hard enough or more likely smart enough as your car is still unrunning and sitting in you're front garden? Do you need a loan, I could loan you some money if you want..I promise I wont rip you off...rofl.
More like throw a hearty dying of laughter, Careful you dont choke on that spoon.
she's up the back under the carport acutally...and no, i dont take money from other boy's parent's
can i borrow 6K please i promiss i wont run away.....
Sif spelling mater on an internet forum as long as you can understand what i'm typing lol
or else i'd alway be in the shit.....
come on matt sling some insults my way i'm very bored....
not from what i hear :P
you're a n00b so i excuse the fact you have no idea what your talking about. Money inherited by me is still my money, perhaps it's the fact you have no idea how to structure a question that you don't get the response you're looking for?
haha i know more than u think i do :kiss::P
and inherited money isnt the same as money u've worked for, its ok matt, im sure theres others out there who have been through the same thing.
Perhaps its because you are a pretentious little (and i use the word in every sense) f**kwit that you have difficulty relating to the so called noobs.
From where i sit you are just another keyboard captain. Full of shit on the net but an absolute miniscule dweeb in the flesh. Please prove me wrong.
No worries...you're choice to be poor. I wouldn't lend you the money anyway, too much money wasted on litigation when you can't afford to pay it back. Plus I don't want to get stuck with a unrunning 89 GTR that i have to sell.
the words of a daddies/mummies boy :ninja:
how many others are part of the got rich parents club?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
