Hello all.
Hey i have notice the 5 blue squares with 0%warning under the trader rating in the profile section and no else has them, can someone tell me what that is.
Edited by subzeroR33
it's your warning level...if it's above 0% it's because you have done something wrong and have been awarded a warning. As it grows so does teh chance of you being banned. You can only see your own hence why you think noone else has any.
OMG I'M GOING TO BE RAPED!
Kidding, I live in Wavell Heights (Chermside/Nundah/Toombul/Kedron are all popular suburbs around mine). Unfortunatly I'm stuck driving my mums discovery until I can actually afford something decent :)
I work in and around there.
I will stalk moms in Discovery's for a laugh now.
I thought i was being a bad boy and had 0%.
Laffo, I don't think she'd care. It's the series 1 that looks older and dodgier then a normal series 1. TDI engine, sounds like a truck, can't miss it.
I need to find where I damaged the front left suspension on it sometime, makes a nice loud clunk when I turn right quickly... Quickly is relative btw.
so mark, what time did u run in ur super quick 34? :)
P.S learn to do a skid buddy :laugh:
P.P.S i have video footage of ur run ;)
dude i the TCS on and it was missing again.. :)
and im not lying lol..
i loaded up the converter and let her out and she bogged.. cause i forgot TCS. then anything above 5k it missed.. its been missing since we got it.. :P
im gonna have to get ther earlier.
i was up in the stands dude
6.5k launch isnt anything special, its what non softcock's launch at :)
after bein out there tonite, im itchin to get my car up and running and do a time! :laugh:
haha
well my GTR is great sitting at home looking pretty..
as if im soft.. TCS is soft.. they dont spin up with it on.. :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
