sorry andy. u get just jap or the perfourmance one..?
u dnt think its good value..
the one on lees car is ok.. but want to change it if the JJ one is good..
sorry i didnt read that properly....I got the forum one
it would be good value if it actually fitted my car :happy:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
