Can you drift though? Or are you just a power oversteer kid right now? Not picking shit, just I can see more value in mods to help you get better...
wat mods u have in mind josh.? im more than eager to learn as i wanna join some of my mates on QR once a month or so..
Mark, if your task manager is still f**ked, here's something you can try.
Start -> Run -> regedit
You're looking for the following two values:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System\DisableTaskMgr
If they exist, delete them. Should give you your taskmgr back. If not, I can give you a version of taskmgr that I've modified a little bit so that it doesn't look to see if it should be disabled or not and just runs anyway.
sounds rough though...
but wat if u cant get the filter off like in the GTR sometimes.. wat u gonna do then..?
struggle, swear and hit it until it comes loose :laugh:
and when it does come off, replace it with a filter relocation kit!
ahve u come across a filter so tight that ur tool only crushes the casing? this is how my one was in the 26, so had to resort to the screw driver
No offence, because I have never met you, but you'r an anal person when it comes to doing things?
Pulling the filter off an rb is easy, when you can pull one off a 1jz, you realize how easy everything else is.
Nothing wrong with using a screwdriver, its old, you don’t keep the old filters dude haha
Noel and Shane are right though, it is being a pussy. Don't own these cars, if you can't bare to see things brake.
Lee's car looks like a good, clean conversion. I'm not sure what is done do it, however you won't need to do any power steering work just for the odd day out there.
I would be looking at at bigger sumps, and oil coolers first to help keep the motor alive, then decent suspension, and mech diff then brakes if it doesn't already have skyline brakes
im not really concerned about things breaking.. well i am. but i dnt mind as i fix it myself.. but still 6k for a BNR32 halfcut aint appealing.. and neither is hitting something lol. but as most knw i barely drive the GTR.. and a S13 panel is 1/10th of the price of a GTRpanel.. :(
its got an oil cooler. but its not a good one.. also its suspension isnt too great but.. that will be fixed.
its GO R33 NA brakes.. so 5 stud come on later on..
STILL RB POWAH.. love RB :laugh:
struggle, swear and hit it until it comes loose :(
same with mine.. but i can manage it.
have u tried a RB26. i have removed the 1jz and 2jz filters mate.. im an ex mech.. i knw they r hard.
and wat do u mean by anal.. ? :laugh:
I do things a little backwards to most people, and maybe “OD” in some area’s, that others don’t see the need.
It’s not an ASAP item, but I would look into a sump baffle, and fitting a much bigger and better oil cooler.
Then, coilovers + all the fruit, 2 way lockers make drifting so much more controllable and predicable, but having had a few I suggest learning to basic’s before getting one, as they can catch you out.
I assume the car already has a decent clutch.
Edited by Nismo_Boy
and wat do u mean by anal.. ? :(
I have, I personally found the 1jz one to have less room. I don't use a hoist, maybe that makes the jz ones easier.
By anal I meant, just from reading whore town, you seem worried? a lot about Lee's car. I duno if this is case?
At the end of the day, its a sports car, that’s had another sports car's motor, that’s bigger shoved into it, hybrids do brake..
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
