hey mark sorry missed ur call on saturday.. my phone committed hari kari so didnt recieve any calls/msgs.. now have a very nice new one which has given me a new toy to play with while at work >:( will catch up with ya sometime soon. for now, lunch calls.
me back too....
Woot!! RWC tommorrow moring!! YAY!!
Then off to see my Lil Bro for that loan!! By dinner i'll be ready for that GTR!! Woot!! :P
thanks to all parties involved :laugh::(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
