wireless on laptop.. just unplug it from desktop still get net access..
ahaha my jade..? did u see her..? wat u think shane.. u knw u like asian/russians..
logan pub please.
i live next to the hyperdome.. 10min walk to cactus jacks.. which ill see u all tomorrow at..
put it this way, i'd be keepin 2 eyes on her if im around ;)
logan pub please.
I have wireless too hi5
I doubt u will see me for the next 6months, atleast
she was soo last year *does gay hand movements*
yeah thought as much ;)
ahaha... funny man...
put it this way, i'd be keepin 2 eyes on her if im around :P
i knew u would like.. ahah lee is just as bad...
wen u do meet her ull be suprised how much of a good girl she is..
also i bet ull drop ur nuts and cant get one word out. :)
also i bet ull drop ur nuts and cant get one word out. ;)
dude, dont tempt me, i have 'history' :P
press delete on first screen or somthing like that..?
anyone got a USB disc thats over 1gb i can borrow for a night?
thats the one, press delete at the start, takes u into a menu and look through until u find the boot sequence
mark u look like a faggy metro and u r a twink for logan sugar daddies
dude as if.. i dnt do my hair and dnt wear anything decent.. only do my hair when im out with her
dunno, but ur missus should be able to answer for me ;)
ok enough talkin bout her..
You gotta do better then that to wana make me drive 1.5 hours to farken Logan Bogan Home
i dnt live in the bogan part dude.. they still forsale..?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
