Hope you've made the right choice for yourself anyway Josh, better than court IMO :P
Anyways I'm off...baibai all :happy:
It's a much better choice, however it is a HUGE effort now to get my license back.
I do weird things, I just didn't want to give the Police the joy and satisfaction of beating me.
lol, what did you get cuaght for??
What time? lol.
In short, I was appealing a suspension, and they were opposing it with 4 years of evidence as to why Im no longer fit to hold a license.
I ditched the license, they can't oppose shit now.
i had my dad take my car to a tail shafting place today, to get them to see if the tailshaft was out of balance at all, and i told them if it was to fix it. bcoz i thought it was slightly out.
anyway dad dropped my car back off at my work i didnt get to drive it till 5pm on the way home and when driving it home then whole rear end has a terrible shudder now. worse then ever before, so i think they have over balanced it or something, i dont know why they touched it in the first place if it didnt need doing. that is what i told them anyway... i dunno i give up aye....
Just skid it, it will either get better or worse
:ninja:
so they'll probably impose some sort of restriction withholding you from obtaining your license for x amount of time or something...lol sucks ass but at least you beat them to it sorta....
damn that sucks, just live in hope that one day it will all be good lol
yeah so annoying, so now i gotta take it back to them to say for them to fix it.
hope they do. i just want it back the way it was now it wasnt too bad after driving it now lol
its like some1 has welded some steel to the tail shaft and its not spinning correctly now causing it to shudder, problem didnt need fixing in the first place by the looks of it, it could have easily been something else doing it, but i thought they would know if it was the tail shaft or not? since they are in the business.
thats correct, however the national data base wont get updated, im not even listed as a licensed driver, shows just how slack they are, and only keep an eye on their own state systems.
So, yeh I could go and apply and take the test for a vic license, just have to watch out for where i drive in qld
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
