real power = skids @ 100+ on teh "super highway"
in the dry :)
ahah shane has got jokes.. asif i dnt knw powah..
ur a bogan shane wers ur V8 and XXXX beer?
i do doubt u mark :)
no, i believe im not a bogan, im one of the very few ppl that live in ipswich that aren't a bogan :)
P.S toohey's new ftw
Whilst the old switch is still there. (flanell shirts, fat mommas in licre and thongs) The new switch is emerging. Its actually becoming quite the yuppyville in certain parts these days, And arent there some tools amid that genre :)
True story, I was at a friend’s house last week, refused to buy any form of alco. I ended up buying a VB tally for $4.95 after being convinced this was some how a good idea. Funny thing is I also own a V8, I really do suck at life it appears
Good times.
DRAGGER is still forsale, however... the whole no license thing eh..
Yea, you see Mario's cars for sale again....has been for a while....stupid fag who bought it put airbrushing all over the bonnet and now he's trying to sell it....it's a tough car in many aspects....looks stupid with that airbrushing though...
Tools are everywhere, but yes in certain areas the concentration is high
Mario's car is good as he is VERY anal, however its only half the car compaird to DRAGGER.
:) dude wtf??? :)
Good times.
rumour has it its got ALOT left in it than 1003bhp :)
Funniest sight on earth is still a big ole ipswich momma standing outside booval fair eating 2 big cream buns out of one hand a slurping a diet coke so she dont get fat out of the other. :)
I know...but it's still a very nice car...750+hp plus the looks...thow in some NAWS if you want to be a dyno queen.
DRAGGER is hawt sauce though!!
:) dude wtf??? :)
Rumour has it, it made that without the gas. And the fim crew and story writers f**ked up on the dvd. I wasn't there, so i dont know really.
I hear another 200 ponies with the right gas set up, maybe more. It's built for it...
funniest sight ever, is woodridge centrelink before it opens....don't go there or you could be shot/raped (guy or girl) or a mixture of both...I felt scared just passing it by in the train. Side note....it's by far the best building there...from what I saw.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
