should i create a thread about it??
go ahead. then ill mention i forgot 1 item which was my AFM. which is fixed and not an issue and complain about me being dodgy wher as i have told u EVERYTHING par the afm.. so why didnt i just cover it all up? like the rust u have in ur friggen a and c pillars.
You should see us in person then ;)
haha oneday ill meet josh..
Mark: Not really, we are just on another level...
Lee: Sure, create a thread, call it;
"I realised I dont want a GTR, even though its in excellent condition, I just dont want it anymore. I need an excuse, oh, it has minor $200 to fix (if they exist) problems that will do".
ahahaha. lee how about u leave it. UR NOT BUYING IT.. just leave it.
Get us $2.5m, and I will make us $1.5-$2m profit...
Can we prove we can make this said profit? Where is the majority of the 2.5m going?? Are we being serious or just dreaming about owning a gulfstream V one day?
Serious, and yes we can prove it. We can have valuations done to prove it based on building plans.
Im talking about re-development in high level high demand areas.
now i'm bored.....
what do you all have planned for the week end??
Driving tonight, mastabation tomorrow, and sunday well.....
Edited by Oblivion
i'm interested, I don't personally have the capital but I know a few different ways in which we could obtain it....would obviously be a long procedure of getting everything together if we wanted to do it...but you never know, could be worth looking at.
How much buys in @ what percent. How long untill I see returns.
jaja
Might put some feelers out and see whats kicking around the market down here atm... If we can find a property/site that has become stale to the market it would be well worth looking into.
Only catch is how much the backer wants in return for his initial investment.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
