They have 4 boobs between them. Which is more than I can say for you! >_<
f**k, some angry pills in here today.
thats it im gonna be angry shit c**t f**k
*Kicks cat*
hmm u have a point there >_<
i sent u an email but i think u'd left already....it was asking if u were still interested in the cf bonnet
Prolly not.....In light of my hankeing for good brakes I dont think I can afford it anymore....that and I was only gonna use it on the track...I should just work on a better way of keeping the temps down!
u should be sweet now uve got the new radiator and oil cooler...time to go make a for sale thread
P.S dont spose u know anyone who'se after a cf bonnet?
skyline market is going to fall even worse now because no teen racers can buy them...hahaha I can't wait until I buy another performance car....i'll be picking a 500hp tack weapon up for 20k and less....sucks to those selling their car....
Now would be a good time to buy a couple of n/a lines. Their value is gonna get hawt.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
