Thats not what Phatboy said, reckons yours is a bodged up shitter.
:w00t::O I was waiting for somebody to say that :ermm:
u mean just shanes anna..? i knw of more factory GTR that are in worst condition but still fine than blown ones.. only a small percentage dies.. and lil shaney joins them..
anyway im off to further my eductation latas whores
No darlin', you'll be a statistic in no time. *whispers* he's "spethal"...
BWAHAHA! I guess when little marki has a better come back we'll hear it, then agian his only cum back atm appears to be him jerking off into a fan.
ouch.... sig worthy....
Wow... according to the 'Your Life' folder thing that Qld Government sent out, I am Obese. :w00t: I honestly didn't think I was THAT overweight :O
Thats just plain BS...those things don't take into account being "big boned"
The lardasses on teh biggest loser are obese...you are not :ermm:
oh hi old man.. still kicking i see..?
boged up shitter..? haha better cleaner than his RB20 S13.. have u seen the run on that..?
look Mark i can reply, what run are you talking about? i aint the one say "err i dont know why i posted my clutch was slipping but its not cos it magically fixed it self"
looser :w00t:
rofl
and theres the 2nd one i was talking about josh :w00t:
On the treadmill puddin. :w00t:
Yar, it would seem so... I watched this show last night where people were morbidly obese. Like 442kgs stylez. f**kin' crazy how someone could eat their way to being that large!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
