Ahahah i'm trying to make Andrew swap computers and then get the dash replacement cos I think it's funkeh! And you've got everything you need right at your fingertips.
u mite have a hard battle...
"Bzzzzzzzzzzzzzt
Too expensive!
The power FC and Hand controller proved its worth on Sunday mmmmm 91 octane"
Anyone that's hope needs to put Dr Phil on - it's f**king hilarious! It's about meddling mothers. This chick watches her 31 year old daughter (who lives next door) and goes rank if she comes home later ;) and she reads her mail, gives her shit if the laundry's not been done. What the hell?!? I'd be getting a divorce from my parents if they did that shit!
"Bzzzzzzzzzzzzzt
Too expensive!
Yeh you're right - he won't get rid of that thing. He likes being able to fiddle with settings when he needs better fuel economy or like you said, on Sunday when we needed it to run on 91 octane :rofl:
Yeh you're right - he won't get rid of that thing. He likes being able to fiddle with settings when he needs better fuel economy or like you said, on Sunday when we needed it to run on 91 octane ;)
yeah thats true, but then we got talking about the self tune for the haltech and if it would be able to do the same thing...but then we decided to wait and draw a conclusion when ben test's it out on his ceffy hahah :laugh:
And the whole 'bzzzzzzzzt' thing is right on the money :rofl:
gold ;)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
