nope ;)
:pirate:
rofl just had the worst ride home from the airport.. toyota avalon, every couple of mins the car would shake like we're going over a cattle grid.. I asked the driver what the problem was he just shrugs his shoulders "been like that for a while"
oh and morning (sorta) whores... i just got back from gladstone.
lol that woulda been a nice and comforting ride >_<
dunno...new stuff i guess >_<
the room has suddently gotten 'phatter' hi lee! how'd that head unit go?
Hey Isaac, I Dont need it anymore, long story, but i will still be keeping the blue beast and i'll just chuck it into a random persons car later down the track lol
Hoe was Gladstone? Whens the big move?
ahh *i smell a piker* bad luck :happy: why get a shitty gtr anyway, they always break lol.
gladstone was ok, cept dinner last saturday was at this shithouse restuarant - $34 for a steak, i asked well done they bring it out rare, i send it back its burnt charcoal on the outside and STILL rare in the middle.. total rip, i'll never go back!
big move is weekend after this, i start work up there on the 2nd april, so guess i move up on april fools day (appropriate >_<)
Sif order well done for any steak!!!!! May as well eat charcol! ....Medium rare FTW...
various parasites such as hookworms etc.. that live in the muscle of cattle, trust me im a scientist, i like my worms cremated before i eat them >_<
Most decent restraunts will refuse to cook a steak medium-well or well done....just kills the flavour and ruins the steak.
well if they accept my order as 'well done' i expect to see only a hint of pink at best, not blood running out of the middle and a cooked area 2mm thick.
If I pay $30 for steak, I like it to taste good...and like I said, theres a reason all the best restraunts in the world cook steaks only rare or medium-rare...or as the Chef likes (which is rare or medium-rare) and you don't get a choice lol.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
