I’m being serious here, not whore town funny shit.
My lip is MUCH worse in person, why do you think one of the reasons I surrendered my license to avoid court and the possibly situation of a huge suspension?
They had 4 years worth of tapes, which they were submitting, of me being verbally violent, rude, making threats and a few of the local officer’s going on the stand to testify against me.
Ask, Matt, his been in the car a few times. I admit I bring it on myself, but when the Police bend the law, to f**k me over I’ll go nuts.
I was being serious too, very serious.
Oh I know. I'll be knocked out cold by cop out of his uniform on the streets, and as you said the good old phone book bashing, I won't be able to do shit. But, the is a risk i have now taken.
Sigh!
Ever asked an angry cop when was the last time he told his family he "loved them" >_< And that maybe he should do it more often.
I’m not implying any future threat action, or even making a threat. However, it makes you think doesn’t it..
f**k, I bring this shit on so bad hahah
i'm with josh, f*ck the cops for all they're worth if u can. caus they arent all inicent that they make themselves out to be, i've had a few run ins with cops that have been un recorded.
I’ve had two in my face, only centimetres away from my face. They wanted me to throw a punch, sometimes I have self-control, lucky these times I did.
Pretty much be f**ked for ever I reckon if you hit a cop, even if you got off lucky in court you would be owned by cops for the rest of your life
rofl, u should know what the ipswitch cops are like, most are a bunch of f*ckwits
Sounds like the local’s here. I was parked out the front of some shops, busy as f**ked, silly me went disabled, fair call I’ll cop it sweet, they were hounding me as I looked intimidating, WTF @ provocation tactics.
I’m like; I’m not even 5 foot 7 how am I intimidating to you, kept on taken cheap shots as I was dressed for work. If any member of the public “bullied” a cop like that they would be f**ked over
i'll bet there are more f**kwit import drivers than cops.....cops target imports due to a bunch of f**khead drivers pulling skids, drifting speeding etc.., rest of import owners act more agro when questioned by police because they are targetted, cops get more agro due to idiot drivers, target them more......its a viscious cycle.
I bet your right.
but living in a small town, with a small amount of cops, your picked on for owning this cars even if you havent done anything wrong. At 1st this was the case, now I do the above to spite the shit out of them.
I'll back down when they lay the f**k off.
lol you guys are funny......
Traffic cops are really just over reacting geekboys prolly some of them are nOObs that have been flamed in car forums and now want to get their own back :happy:>_<
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
