Insert something here! wtf. are we talking clutches or crotch's
u f*cktard (yes thats right i called u a F*CKTARD) i said that instead of the company's name, NPC. u'll hear me taking the piss outta them quite alot :dry:
u f*cktard (yes thats right i called u a F*CKTARD) i said that instead of the company's name, NPC. u'll me me taking the piss outta them quite alot :dry:
That will be MR. TARD to you. I only let friends call me f**k. :)
Answer me this puppers. Does anybody make a lip for the standard 33 series 1 bar. f**k all the aftermarket bars. They look like a block of flats and arent worth the trouble I see dudes going to to avoid gutters, speed bumps etc.
there are a million front bars that you'd probably like and your car isn't lowered anyway, is it? But yes, there are lips you can get, but clean aftermarket bars look better.
Show me a clean one. It seems to be a competition to see who can put the most tiers, slots and fins on the one front bar.
Monkey Wearhouse(sp)? it saw some very nice kits from them...
just add a lip to the bottom of yours.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
