ha ha ha ha she's so effing lame.. don't worry lil miss, i'm starting fights for you :nyaanyaa:
LMFAO@ "joke hitler" from that video bahahahaha
p.s. they should all die in a fire....
yer I hope flesh eating bacteria crawls into her womb and devours her unborn fetus ..
And then she 'accidentally' gets sodomised with a splintery baseball bat covered in razorwire..
my kind of situation...nothing like tearing someone apart....:S
ooookkkk....medication is your friend.
bahahahahahaha if you say one more word i'm gonna blow my brains out
I HAVE A GUN! .... I do... I have a gun....
BOOM
wouldnt be much to see if u did blow ur brains out :P
:nyaanyaa:
Pics of you blowing?
3rd'd
Anna I f**king tell you what I'm gunna f**king start slitting f**king throats soon .. Those f**king hepatitis c ridden f**king crack whore moles .. I hope her child grows wooden legs and gets caught in a f**king bushfire or a f**king termites nest .. f**king diseased ridden whore :ninja::P:P
GRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!
boostloosing crusing?
lol nah these girls deserve worse than what Kitas is saying.. LOL
don't worry keets... she's fat, preglet, and ugly.... we should feel sorry for her... which I do....
Does anyone else know who these people are?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
