you need some better mags.
:D
bite me you blow job....
lol your a blow job :(
but really i wish i could of found thoose zeptas in 18's
yay!
mine moving a little slowly... i ran out of money!
have you seen pics of mine yet? I know i porbably say this everytime! lol
lol yes i have seen the pis of the red 180....
yeah it's hot huh
need some decent photos though, and i need to actually give it a wash.
lol in about 3 weeks up here we wont be allowed to wash our cars, cant even break out the water to wash bird shit off...
dam level 5 water restrictions :wave:
P.S. Mine is sexyer!!! >_<
PICSORBAN!!?
not even at the car wash?
Looks like it's all but died now but ffs people, can everyone stop stirring up shit on BC? I don't know what's been happening and I don't really have time to find out atm, but the 'reported post' PMs are getting a bit beyond a joke and I can't say I completely disagree with them.
want a hug???
i wasn't involed but i wanted to be >_<
hi
yes at the car wash but all that water is recycled >_<
now with clear indicators :wave:
hot!
but see, I didn't say mine is hotter coz I'm nice because it really is hotter
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
