S'matter fatty. Your little dick too hard to find so you can stand up to piss.
see what i mean >_<:ninja:
you lucky your an old man and i have a small penis... or i would be very up set :wave:
drama?
lol nah, been busy as fark all morning and just cbf doing anything else
i hate people who can't spell.
Me too. I was a speling champeon at school though so my posst shoudl be eesy to reda.
Tell me more about these 10hp ecu mod thing u spoke of on gsx the other day
link?
Celicas? Ew.
i think the reason you lot were all banned, is because you came to Boost with the sole intetnion of shit stirring, as can be found back a few pages in this whore town thread. this was found, and obviously acted upon.
i do understand where you're coming from with the double standards, it happens, and i know im not the most liked person on Boost, many times warnings given to me, but exempt from others.
i didnt come here to stir shit, more with the intention of calming shit down a bit >_<
get her to remove the bans, and then things will settle down.
or this may just keep on happening, and ban's wont stop us, there are ways to overcome bans if we feel the need :wave:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
