Oh and for both of the people in the world who haven't already seen it, here's the segment from Ghost Rider, with his 499 semi-naked Hayabusa turbo...
http://www.youtube.com/watch?v=L6Kt7dvEEGo
mayyyyyyyybe's trying to save moneys but i might come in for a bits >_<
Bah come out, I can't speak for the others but I'm happy to pitch in if you need a hand :wave:
ghostrider for the splat!
haha indeed
I'd love to know who he is (I'm sure the cops over there would too lol), cos DAMN he can ride. He's insane, but there's no denying he has skills :ninja:
I would kill myself.
I want it
Me too, and me too
Bah come out, I can't speak for the others but I'm happy to pitch in if you need a hand :ninja:
ha ha ha awwwwwwwwwwwwww you so lovely's!!!
I gots moneys sillys :wave:
Just trying to save some for my move :P
BUT cos u's are so nice to me, now i'll definately come >_<
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
