seems like u have no respect end of story.
dave, we wouldnt be so uppity if we only got 'banned' on boost, but it has dragged over to SAU, and this is why we are 'uppity'.
Fair enough if people complained about us when we were in the whore thread on boost, but no1 in there did, except for a certain mod, which put the 'ban' on us, and then obviously some1/s have come over to SAU, complained again, and yet the first mod told us to stop (which we did) a second admin came in some numerous hours later and gave us all 10% warning, which is complete bs.
So sue me? I'm a pretentious little up-start brat from Noosa, who hides behinds his fathers money and always gets away with rubbish.
As I keep saying, take a ticket to sue me, no one has won, yet.
A+
Sum's it up perfect.
Well, at least your honest.
Dunno wtf you're talking about RE: bagging you. She's said nothing about you specifically, although I certainly have.
for fu<k's sake, wake up to yourself.
any more bashing of Boostcruising or its members by anyone in the QLD section will result in an immediate 7 day ban.
jeez mud settle down, it was a joke, and even if it wasnt it was not aimed at any one in particular nor was I involved in the original incident. :laugh:
You are much more than that you tosspot. You are also Jobless, licenseless, and your ride is a woodridge special. Get a haircut and join the army you bum.
p.s. I was owned you camel jockey. LOL
