p.s., best thing abotu whoretown is that you can come and not read anybody elses previous posts and just say what u want.. plus im bored at work and just feel like ranting somewhere..
I like pie.
I like pie too..
someone tell me why i only pulled 160rwkw on the dyno =\
FMIC, 3" turbo back exhaust, Pod Filter, Cold air intakes, Boost set to 12 psi, SAFC2 tuned. i was hoping for 180-190.. much disappointed :happy: It was on Matt Spry's dyno, which i know reads a little low, but was still expecting to hit 175-180 on it..
One thing that may provide some clues (tho im not sure how). When we did a run on the dyno with the SAFC2 zero'd, the AFR's were much higher than would be expeced from a stock ECU running 12PSI.. (like, A:F in the 13's)...
we ended up tuning the SAFC to PLUS 5-10% air so it richened up the mixture more.. isn't it normally the other way around. And if so, what would cause the car to run lean like that ? Could it be the reason why im not seeing the power i should ?
GO WHORETOWN TO THE RESCUE
Yes I've been browsing the C&H site... but could this be the Plough Inn?
the crazy thing was that I kept screaming out "some B*tch got shanked!* and me and Anna kept yelling out that "bring the vaseline and the straight razors"
bahahaha
We didn't even know :happy:
Hahaha I can see you guys doing this:
home made or McDonald's?
Home made ftw
I like pie too..
I wouldn't have thought that figure was all that bad... maybe a little bit low but not awful? Lean AFR's could point to dodgy fuel pump, blocked fuel line, fuel filter that needs replacing etc, or possible the AFM reading wrong.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
