who are these idoits? I logged on and didnt see any thread matt
I dunno, I logged on when I got that PM from John, but I think he's deleted the thread and banned those involved....
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
