I was amzed though, to see a very very angry and turbo, and FAST old thing. it looked like a camry, but not. sorta like a 4 door old soarer,... i dunno
me thinks 1j cressida?
i miss my old mx83 cressi :unsure:
awww im going to miss you Isaac, you better keep whoring in here..
hahah appreciate the sentiment bryn....just dont get TOO close eh? :unsure:
i'll probably be offline for a while, i have to find a place get phone and stuff hooked up. I can predict i will be whoring on a whole new level, living by ones self (when g/f not in town) plus copious amounts of on call work for rockhampton hospitals = lots of nights stuck at home waiting for phone to ring.
oh and incase anyones interested... to move basic shit - a bed, mountain bike, bookshelf, small bar fridge and 5 boxes of misc crap is going to cost me some $800 AND will take 8 freakin days to move, they charge me $50 to put it into storage, 17$ per week in storage, another $50 out of storage plus $300 'delivery' to final address in rocky :unsure::wave:
i want to buy a removals business. Damn, imagine how much it would be if i actually owned STUFF! ;)
Yeah that would suck,, being stuck in rockhampton, not allowed to drink lol
meh the odd drinkie is ok, so long as you're capable of driving etc its fine theres no rule against it. I dont really drink that much these days so doesn't bother me much anyway..
medical scientist - basically i test blood (and sometimes other gross stuff) for diseases - infections, anaemias, leukaemia etc... also do blood transfusions, drug screens, all sorts of stuff really.
For the last 2 years i have been a 'relief' scientist meaning i have worked up and down the coast in most of my companys labs over qld from cairns to tweed heads, inland to emerald, stanthorpe etc.. its been fun but i need to unpack my suitcases and settle down for a while. Sick of living out of motel rooms and its hard to have a life on the road :D
oh ok...sounds interesting...well at least you'll be in the one place now.
yeah it was time to move on... a year in rocky will give me a chance to put my feet up, get my bearings on where to go next. Either i try get a government job, or look at working overseas, or go back to uni and do something different...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
