pity i do - its in your email dumbass :P
also your mum has no clout in this organisation - :)
as if thats my real last name... :)
she's a bitch when she wants to be, im sure she could (i dont say that, kapish? :huh:)
where r u going? (no, im not even gonna guess ur name cuz i have no idea if it's not your display name)
ahhhhh can i get that in english please? :D
hey shaneh!!!
MATTEH!!!!!
rockhampton..i WAS going to buderim but got offered more incentive for rocky as noone else was stupid enough to want to work there hehe :) At least it puts me closer to my g/f - she lives in bundaberg.
anyways i'm on a 12 month contract up there so i can handle it.
oh that's a shame. i live in buderim. i got two guys living with me at the mom but prob kicking one out VERY soon lol Dont even ask... i'm just gonna say immature alcoholic tryhard 21 yr old! (who sprews alot erg)
yeah i think you replied to a thread i made about moving to buderim about accomodation.
2 guys living with one chick tends not to work out...see it happen a few times
2 guys living with 2 females worked last time, no probs except from the neighbours!! But they were older.
Since i've let two guys move in (1 being my bro so it's not that bad) i've got a lock put on my bedrooms door lol if i didn't have a ensuite well... it just wouldn't happen !
Gemma says:
whats with the eh on everything??
Josh says:
i think its a nerd thing?
Josh says:
gemmah!
Gemma says:
deffinately a nerd thing
Josh says:
with out a doubt
Josh says:
but im short, cute and fluffy so it makes it all ok
Gemma says:
ha ha - fluffy
Josh says:
fluffly like a puppy
Gemma says:
what kind of puppy
Josh says:
lassy dog?
Gemma says:
oh i see - so the description should be short, cute, fluffy and heroic?
Josh says:
this is true
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
