ohhhhhhhhhhhhh I can call u more often if u'd like :blink:
*giggles* :happy:
It was funny though
o'rly, this could be a good thing? :laugh:
lol yes it was
he better or he wont get his percentage. Give it to him on the edge of a cliff for guaranteed push back.
i'd shuddup or i may just 'accidentally' snip a brake line when i work on ur car :happy:
o'rly, this could be a good thing? :happy:
lol yes it was
quiet down you, I am negotiating to get another stock line in trade. Do you mind the feel of velcro?
you farkin WHAAAAAT! bout time too. 0413 863207 or h. 32886483
For a good time call Noel
Oh god, old man rivers what are you doing!! Your getting calls at 3am when the clubs close :happy:
Hell yeay, i am makin a mint. How much is 80 five cent coins?
Oh god, old man rivers what are you doing!! Your getting calls at 3am when the clubs close :blink:
dont forget the random burling's!!!!!
ahh good times :happy:
front AND rear lines it is then :happy:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
