yeh coz its not a real HKS ;)
Serious though, what else do you have? What power are you making at what psi and where? Simons maroon R33 is a self tune, self built and makes 270rwkw give or take everytime minus on an allstar dyno
Apexi AX53B70 rebuilt engine, cams, power FC 230rwkw at 14psi at allstar
while I love drags i will be doing sprints as well. so the turbo selection is critical. Will definitely be looking at pon cams and adjusto exhaust gear as well.
the stage 3 hiflow of which i speak is the slide variant. will look for specs later.
Prawn cutlets and seas scallops. mmmmmmmmmmm
why not a 2835 range turbo then...??
Thats what I said too, i was leaning towards the 25/40 as i thought Noel wanted his car for track, untill u said other wise. the 2835 would be a shoe in, with sane boost levels.
Get a HKS 2835 and call it a day Noel.
Indeed, for Noels application I think it's 2835 FTW!!!
2835 for sure. room for the drags, nice match for the track.
I have tentively bought this, mate is in sydney this weekend and will check it out.
http://www.skylinesaustralia.com/forums/in...c=80164&hl=
jesus that is old....was looking at it for a replacement engine when I punched the rod out of my old 33..that was almost 2 years ago!!!
Bit more then just a set of forgies.... If what Andy is saying is correct see if you can go for a ride in that car, a 3037s making 1bar at 3000rpm is NUTS.
so, 3000rpm with a built motor, with head work and the tomei cams u speak of will make me jizz
ya. it will need to be looked at closely to make sure its been stored properly.
3000 my ass. wink wink.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
