like everything...such as my list above lol.
Mate im off to bed have to work in the morning, I would be here all night if i had to type out a list like that :laugh:
Maybe another time catch ya later.
I got my license today! ^_^
but im sitting here, on a firday night, jealous of even the BOGANS are having fun out on the streets, and im stuck at home with no car in driveway (long story)
but other than negativity.....whats goss people?
Anyone here have plastic chromies like i do? :laugh:?
i went to humble pie tonight..... was awesome, few cars there for the meet up they hold on the last friday of every month. mostly old school v8's and hot rods but there was some nice cars there.
some cock bags were yelling shit out at my car as we left, like "get a v8" and shit but they arent the real v8 boys just the young wanker followers who dont have cars....
Edited by 85URK
even 3K willbe enough they will see you can save money and manage it good , they mite give it to you then or try and different bank. i got my first loan of 18K with a job that wasnt permanent or fulltime ( i was fulltime causual) and iin that job i was affected by weather aswell, also they said i didnt earn enough to take out the loan but they lady said il write down here on this form, that she spoke with my boss and work will be picking up soon and you will have a constant cash flow in the next 8 weeks. and i got approved. too easy, she looked after me though.
Well, I'm hoping to get a buttload of overtime if work will pay up for the past week. Still it's not really sustainable, so I've been trying to budget everything in. I haven't actually gone to a bank yet to see what I can get, just working out what I can repay from their advertised rates and whatnot.
So far it looks like my best option will be a QPCU Personal Loan, don't need to f**k up my credit history and lose a car at the same time and the rate isn't that bad for unsecured loans.
(Yes, already joked about QPCU funding a stereotyped hoon car :laugh: )
Will hopefully get a reply from our finance person at work to see if I can cut the tax I pay down a bit (I forgot that they probably had it down as a second job from when I did part time work for them). But failing that, I'll just have to save a bit, won't take long as I don't really spend much (trying to cut down buying computer stuff until I get a car).
Did anyone see that accident at Alderly today it happened right in front of me.
The white pulsar was clipped in the rear and monted the footpath and hit to old ladies who were doing there shopping.
I had a first aid kit in the car and thought i could use it, but her lower legs were busted up real bad down to the bone massive holes and one calf was snapped in half didnt look to good.
So that was my morning.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
