like everything...such as my list above lol.
Mate im off to bed have to work in the morning, I would be here all night if i had to type out a list like that :laugh:
Maybe another time catch ya later.
I got my license today! ^_^
but im sitting here, on a firday night, jealous of even the BOGANS are having fun out on the streets, and im stuck at home with no car in driveway (long story)
but other than negativity.....whats goss people?
Anyone here have plastic chromies like i do? :laugh:?
i went to humble pie tonight..... was awesome, few cars there for the meet up they hold on the last friday of every month. mostly old school v8's and hot rods but there was some nice cars there.
some cock bags were yelling shit out at my car as we left, like "get a v8" and shit but they arent the real v8 boys just the young wanker followers who dont have cars....
Edited by 85URK
even 3K willbe enough they will see you can save money and manage it good , they mite give it to you then or try and different bank. i got my first loan of 18K with a job that wasnt permanent or fulltime ( i was fulltime causual) and iin that job i was affected by weather aswell, also they said i didnt earn enough to take out the loan but they lady said il write down here on this form, that she spoke with my boss and work will be picking up soon and you will have a constant cash flow in the next 8 weeks. and i got approved. too easy, she looked after me though.
Well, I'm hoping to get a buttload of overtime if work will pay up for the past week. Still it's not really sustainable, so I've been trying to budget everything in. I haven't actually gone to a bank yet to see what I can get, just working out what I can repay from their advertised rates and whatnot.
So far it looks like my best option will be a QPCU Personal Loan, don't need to f**k up my credit history and lose a car at the same time and the rate isn't that bad for unsecured loans.
(Yes, already joked about QPCU funding a stereotyped hoon car :laugh: )
Will hopefully get a reply from our finance person at work to see if I can cut the tax I pay down a bit (I forgot that they probably had it down as a second job from when I did part time work for them). But failing that, I'll just have to save a bit, won't take long as I don't really spend much (trying to cut down buying computer stuff until I get a car).
Did anyone see that accident at Alderly today it happened right in front of me.
The white pulsar was clipped in the rear and monted the footpath and hit to old ladies who were doing there shopping.
I had a first aid kit in the car and thought i could use it, but her lower legs were busted up real bad down to the bone massive holes and one calf was snapped in half didnt look to good.
So that was my morning.
